Print Problems at first layer. Advice needed
marc.k
(@marc-k)
Hello,
I tried a lot of settings but I can't seem to fix this.
https://imgur.com/a/PXq0p
I extrude at 1.2 which is high but I noticed some underextrusion if I go lower.
This is regular PLA.
I Print at 215*c and 55 *c bed.
I use 0.4mm layers for this print. The nozzle is also 0.4mm wide.
My z axis is already at 0.6mm
Help would be greatly appriciated.
Postato : 20/09/2017 9:54 pm
AJS
 AJS
(@ajs)
Re: Print Problems at first layer. Advice needed
Please try the steps found here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
If that does not help, please comment back here and we can see what we can figure out.
Start with pre-sliced files, then your own.
Postato : 21/09/2017 1:00 am
JeffJordan
(@jeffjordan)
Utenti Moderator
from my experience 0.4mm layer height simply to high !
usually the slicer settings provide up to 0.35mm... but that's somehow still problematic.
go for 0.2mm or 0.3mm for quicker results.
Postato : 21/09/2017 9:37 am
