Print Failed after a certain height
karan.s
(@karan-s)
I have assembled the printer exactly according to the manual. This was a print that failed, all verticals prints failing in the similar way. Flat prints come you brilliant. Could someone guide me how to fix this.
Thank you.
Napsal : 08/12/2015 7:02 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Print Failed after a certain height
Hi Karan
First thing to check is the belt tightness. Make sure both X and Y belts "ping" like a guitar string.
What material are you using? PLA or ABS? If its ABS, make sure that the printer is away from any draft and that the part fan (at the back) is turned off whilst printing.
Peter
EDIT: One other thing - you need to ensure that the cables are routed correctly and do not interfere with X/Y movement at a particular height.
Napsal : 08/12/2015 8:47 am
