pla leaking over hot end
nate.l
(@nate-l)
Recently changed to a 0.25 nozzle. Now the pla is dripping over the top of the hot end down to my prints this https://drive.google.com/file/d/0B-wD0zCusJAucXA1MXhMazl0c0E/view?usp=sharing
i can't tighten it any more as the wires will not allow it. Will I need to remove the whole thing to tighten the heater block? As well i noticed my nozzle setting was 0.4mm would this make a difference as well? Thanks for any help
Napsal : 05/03/2017 1:35 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: pla leaking over hot end
💡 when pla leaks over the nozzle, then the heatbreak and the nozzle haven't "kissed" inside the heatblock.
if you only unscrew the old nozzle and apply a new nozzle the whole system might leak.
➡ check thomas sanlanderers video on how to change a nozzle.
Napsal : 05/03/2017 2:30 am
nate.l
(@nate-l)
you're right, think this might have been my problem, https://drive.google.com/file/d/0B-wD0zCusJAuSElJTEFwQzVKcVU/view?usp=sharing
looks like the 0.25 thread portion was shorter than the original nozzle thread. Where is this specified when you buy a new nozzle?
Napsal : 05/03/2017 6:41 am
