PINDA probe to loose
andreas.j
(@andreas-j)
Hello forum,
today my PINDA probe loosend itself. I checked and even when the screws are tightend, I can turn it easily with my fingers.
Is that supposed to be this way?
I tried tightening the screws some more, but they are already quite tight and I am scared I break the plastic part.
As a first aid I screwed the screw that came with the PINDA into place from the bottom, kind of like a counter screw. So far this tightens the loose probe.
I marked the probe and screw to see if it turns again.
Any recommendations?
Thanks!
Veröffentlicht : 14/04/2017 9:08 pm
Rben13
(@rben13)
Re: PINDA probe to loose
You can screw the PINDA down until the edges of the part holding it are pressed together. I had a similar problem. The printer would seem to print fine, then the vibration would move the PINDA and everything would go nuts.
Good Luck!
Veröffentlicht : 19/04/2017 4:05 pm
sami.p2
(@sami-p2)
We had the same problem with the MK2S PINDA mount, wrapping a piece of electrical tape around the threaded part of the PINDA was enough to allow it to be tightened down.
No ill effects, at least not yet.
Veröffentlicht : 19/04/2017 5:13 pm
andreas.j
(@andreas-j)
Thanks for the hint!
So far my setup has not been moving again *knocking on wood*
Veröffentlicht : 21/04/2017 12:12 pm
