Only one Z stepper working
Jozarth
(@jozarth)
Hello, I just finished assembling my printer and not all is well. Only one of the Z-axis steppers is working. I got into the calibration self test and it started to move the Z and only one side was moving. I marked one of the two Z stepper plugs so I was sure I knew which was which and swapped them to check if it was the motor or the board and when I tested again the other was moving (confirmed again by switching back) so it seems to be a possible issue with the board. Has anyone had a similar issue and have any advice? Thank you.
Napsal : 22/08/2017 6:23 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Only one Z stepper working
... so it seems to be a possible issue with the board. ...
it's very unlikely that something of the electronics is defective, because both z-steppers are connected in parallel.
check the connector that leads to the stepper that doesn't work, most likely that one of its four pins is misaligned or broken.
Napsal : 22/08/2017 9:35 pm
henrik.w
(@henrik-w)
Hello joseph!
Perhaps is it a broken copper trace on the rambo that is the culprit or maybe a faulty connector on the cable. The connector can be opened to inspect the copper strands by using a needle or a scalpel to unlock the small plastic tabs and gently pull the wire simultaneously. Note that it may be very hard to actually see a broken copper trace on the rambo - so maybe you can use a multimeter as well as a magnifier...
/henrik
Napsal : 30/08/2017 5:11 pm
Jozarth
(@jozarth)
Thanks everyone, this was just a case of me being misreading the diagram. I had plugged the z motors into the bottom two slots on the board and the e into the ome that is to the side of the one second from the bottom. That was a mistake because it is the two that are side by side that are the z and the bottom that is the e. Thanks for the help, sorry it was just me misreading a diagram.
Napsal : 30/08/2017 8:16 pm
