Nozzle diameter!?
Flavius-Tech
(@flavius-tech)
Nozzle diameter!?
Hey there, i just assembled mk2s printer 2 days ago, it might sound silly, but i ask what type of nozzle come by default with printer?
I saw the nozzle is market with 3 points.
I also bought an extra nozzle and that too have 3 dots on sides, i order 0.4 nozzle, and from my knowledge those points indicates the nozzle size, 3 points isnt 0.3, and 4 points should be 0.4 nozzle size? I have some issues with calibrating first layer.
I wanna make sure the nozzle is 0.4.
I have some real nice prints but some of them appear with some marks on outer shell.
Opublikowany : 30/07/2017 3:45 pm
AJS
 AJS
(@ajs)
Re: Nozzle diameter!?
The Prusa comes with a 0.4mm nozzle.
You may want to try calibrating your extruder (steps/mm) That can help.
Opublikowany : 30/07/2017 3:53 pm
richard.l
(@richard-l)
Member Moderator
Check here for dots-nozzle size.
3 dots = 0.4mm
Opublikowany : 31/07/2017 9:15 pm
