Not extruding any material in 1/4 of object
SlowMN
(@slowmn)
Not sure why it is doing this. It will randomly pick a corner and not print it.
See the attached image
Any suggestions?
Napsal : 18/04/2016 11:45 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Not extruding any material in 1/4 of object
Hi Jake
That looks like a calibration issue; bed too high at that point.
Also the small gaps in the other part of the layer looks like you need to ensure the filament drive gear is clean and possibly also clean the nozzle.
Peter
Napsal : 18/04/2016 11:49 pm
SlowMN
(@slowmn)
Ok I will double check those suggestions and see if it changes future prints. I normally use a level to make sure the bed is correctly positioned.
I just let it keep printing and now it looks like this
Did it essentially fix itself?
Napsal : 19/04/2016 12:17 am
PJR
 PJR
(@pjr)
Jake
Yeah, that does happen. Higher layers will print fine and effectively fix the model. The only danger is that the filament gets worn through by the drive gear and then cannot feed, but once the first layer is printed and the filament is still feeding, then all is OK.
Peter
Napsal : 19/04/2016 9:45 am
christophe.p
(@christophe-p)
Member Moderator
It really looks like a calibration issue.
In addition to using a level, did you double-check using a business card to ensure the gap is the same between the nozzle and the bed, on each corner ?
I'm like Jon Snow, I know nothing.
Napsal : 19/04/2016 11:43 am
Paolo
(@paolo)
Jake,
During the bed calibration procedure you have also to be sure that no gaps are present between the Z-adjusters and the Y-carriage:
Every time you are turning one Z-adjuster in order to calibrate glass-paper-nozzle, the bed would tend to rise. In case, push down the bed with your thumb and repeat the adjutment.
I'm a printer newbie but already managed with this issue.
Ciao,
Paolo
Napsal : 19/04/2016 3:30 pm
