Need help with new printer
gene.s2
(@gene-s2)
Hello,
This is my first post on the forum and I would like to get help.
So a recently I managed to get an i3 plus assembled. However, it would not work .
Initially, when I first assembled the printer there was a max temp error but the printer would still turn on.
I ended up making a mistake by switching power cables for the extruder and heat bed cables which I fixed right after after customer support told me how.After that, the person from the support checked if everything was wired correctly after sending a picture of my rambo board and the connections.
However, the main problem comes now when now I try to turn on the printer , it doesn't show any life at all(int the lcd or the extruder parts). I know that the PSU is still alive (green led inside lighting up) and I set it to the right power setting.I and customer support are am stumped on what to do.
Could anyone help me here my printer not turning on?
Note:It's my first 3d printer and my first time building one.
Postato : 17/07/2016 7:10 am
Cipis
(@cipis)
Utenti
Re: Need help with new printer
Propably blown fuse on rambo or PSU.
Postato : 17/07/2016 11:36 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Yeah, check the fuses, but not sure it's that; one fuse is for all the electronics, so the LCD should still operate if the light is on in the RAMBo.
Post a picture of the 2 ribbon cables connected to the RAMBo.
Peter
Postato : 17/07/2016 11:41 am
gene.s2
(@gene-s2)
I did manage to fix the problems with fuses . However, now I'm getting a problem where when I try to calibrate using auto home, the y-axis keeps going backwards
Postato : 18/07/2016 8:32 am
henrik.w
(@henrik-w)
Hi!
Y-axis going backwards?
1. Do you mean that it goes in the wrong direction(away from the endstop)?
2. Or - do you mean that it keeps moving even after it hits the endstop?
Solution for 1 -> Check that the connector of the Y-axis is inserted in the socket in the right direction(compare with the colors of the cable with other axis).
Solution for 2 -> Check the endstop that the carriage hits the switch on the endstop. You can also press the switch before the carriage reaches the endstop and see if it stops.
/Henrik
Postato : 18/07/2016 8:57 am
