        motor installation quesitons [SOLVED]
Each motor has a different length wire. Can you clarify which motor/wire length goes where?
large motor, long cable = ?
large motor, short cable = ?
small motor, long cable =?
small motor, med cable = ?
small motor, short cable =?
                            Postato : 13/06/2015 7:54 pm
                    Re: motor installation quesitons
Hello tim.o!
It's easy 🙂
large motor, long cable =  Y axis
large motor, short cable = X axis
small motor, long cable = Extruder
small motor, med cable = Z2 (The Z motor which is on the side of frame without electronics)
small motor, short cable =Z1 (The Z motor which is on the side of frame with electronics)
Michal Prusa
CTO
                            Postato : 13/06/2015 8:02 pm
