MK2 first run problem
occupied_brain
(@occupied_brain)
I bought an MK2 kit, and have assembled it but I'm having some problems in starting it. .
checked the wiring twice, looks correct but whenever i power it on, nothing happens. Only the PINDA LED and the Rambo LED light up. Sometimes the LCD lights up, completely blue, no black squares as others have experienced, but this happens only for a second or so and the LCD is blank again.
Fuses are ok.
Attached are the photos of the wiring.
Please help.
ASAP
Thank you in advance.
Posted : 29/01/2017 1:27 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: MK2 first run problem
welcome to the club 😉 .
can you post a picture of your lcd assembly (pcb / the side with the two 10pin connectors, the lcd contrast trimmer and the sd-card holder) ?
then: can you connect your i3 MK2 to your computer and control it through pronterface ?
Posted : 29/01/2017 3:16 pm
david.b14
(@david-b14)
Also see if you can get activity on using the USB port using PonterFace (sp?) or OctoPrint.
Posted : 29/01/2017 3:25 pm
