Marvin not loading from SD card
Ard van der Leeuw
(@ard-van-der-leeuw)
Hi everyone,
I received my assembled MK2S today, and of course immediately unpacked it and set it up!
Initial Prusa Logo printed fine (minor issue during the start of the print, which I'll investigate later), so then I wanted to print Marvin (the little 3DHubs guy). However, when selecting the gcode file from the SD-card, the display seems to 'freeze' for a little while and then returns to the info-screen. I tried several times, but it just won't load the Marvin file. The Prusa Logo gcode loaded fine, and instead of Marvin, I started printing the Batman file, which loaded without issue as well.
Has anyone else had this issue as well?
Ard
Napsal : 17/05/2017 10:11 pm
Nomad965
(@nomad965)
Re: Marvin not loading from SD card
Not me... just open the Sdcard on the computer delete it, and download it again, its available on the prusa site.
Prusa i3 MK2s MK2.5s Mk3 Mk3s BearPrusa Zaribo 320 - Kit Build - Rc Driver - Tweak freak...
“I know nothing about surpassing others. I only know how to outdo myself.” -Bushido-
Napsal : 17/05/2017 11:04 pm
xerdo
(@xerdo)
I ran into this - try clicking it again when you think it's "frozen", it will probably load.
Based on my interactions it seems like the firmware wants to scroll through the entire filename before it will load the model. If it hasn't finished scrolling clicking on it will just make it scroll faster until it gets to the end of the filename, then you can load it.
Napsal : 17/05/2017 11:07 pm
