I3 mk2s hot end replacement
hugues.p
(@hugues-p)
Hi , i just broke my hotend with the threaded rod that snaped. I would like to know wich version of the e3d v6 i need as a replacement?
Respondido : 14/01/2018 7:20 pm
Re: I3 mk2s hot end replacement
Is it just the heatbreak that you have broken,
if so, you shouldn't need to buy a complete hot end.
just the heatbreak
Respondido : 14/01/2018 8:02 pm
hugues.p
(@hugues-p)
hi, issue is that everything is jammed together, because i had a leaking probably due to the fact that the nozzle was not in contact with the rod. tried to screw the threaded rod and then..., i have probably damage the temp sensor and the heater is jammed in the block, i prefer to order a kit so iam sure everything is ok, i wonser wich one, 12v or 24v
Respondido : 14/01/2018 9:28 pm
TonyL
(@tonyl)
MK2 is 12v. The Prusa shop sells it, but you can surely find the E3D v6full kit elsewhere if you prefer depending on where you are located.
Respondido : 19/01/2018 2:20 am
DevDoc
(@devdoc)
That looks like the old version. You should consider the Block and Sock upgrade kit available from E3D or its vendors and or Amazon. It comes with a new thermistor (cartridge style, the new heat block and a silicon sock. You would just need a heat break in addition to get up and running while being upgraded at the same point. It's a nice kit, and the socks are fantastic for keeping the block clean and stabilizing the temperature.
A heat gun might help free everything up as well, and then you simply need a heat break.
Respondido : 25/01/2018 5:06 pm
