Heatbed temperature calibration?
Boby
 Boby
(@boby)
I already made PID tuning for my extruder and the fluctuations are gone now.
But I also measured the temperature on the heatbed - and it tends to stay 3-5 degrees below the value shown (e.g. display shows 55°C, I measure 50°C).
I found, that there's also a heatbed calibration available in Marlin:
M303 E-1 S60 c8
My question: Is this possible on the MK2S as well?
I searched the forum and the internet in general, but I didn't find a reliable answer.
Thank you!
Napsal : 04/06/2017 2:17 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Heatbed temperature calibration?
Yes. Apply the settings using M304.
Peter
Napsal : 04/06/2017 3:21 pm
JeffJordan
(@jeffjordan)
Member Moderator
details could be found here.
Napsal : 04/06/2017 4:44 pm
Boby
 Boby
(@boby)
Jeff, peter: thank you - I was able to calibrate the heatbed.
One remark: I tuned the heatbed at 100° which is correct now (100° = 100°). When I do use lower temps (like 55° for PLA), there's still a difference of 5° (55° on the display = 50° on the heatbed).
And: It took way longer than calibrating the extruder
Napsal : 05/06/2017 12:00 am
PJR
 PJR
(@pjr)
Yes, there will be; you need to calibrate the different temps.
This is why I include the various PID values in slicer gcode (related to the material used).
Peter
Napsal : 05/06/2017 10:28 am
Boby
 Boby
(@boby)
You mean, you send the M301/M304 command at the beginning of your gcode to the printer?
Good idea! Is it necessary to store them with M500 also (as part of the "preprocessing" gcode?)
Napsal : 05/06/2017 11:13 am
PJR
 PJR
(@pjr)
No it's not necessary to store them in E^2
Here's an example of my start GCode:
; Prefix G-Code
T<EXT+0>
M201 X1500 Y1500 E900 ; set default acceleration
M301 P23.14 I1.78 D75.12 ; set PD for extruder heater
M304 P56.09 I2.39 D328.54 ; set PID for bed heater
G21 ; set units to millimeters
Peter
Napsal : 05/06/2017 11:34 am
