Heat Shrink
What is the function of the heat shrink on the threaded Z rods?
Thanks.
Glenn
Veröffentlicht : 30/01/2016 11:02 pm
Re: Heat Shrink
Hi Glenn
The heat shrink is to secure the push-fit rod/plastic sleeve.
When shrinking, it should overlap a couple of millimetres at both top and bottom. The threaded rods must be firmly pushed down before shrinking.
Ideally, the shrinking should be done with a heat gun at about 250 degrees; ensure it is well shrunk and be careful with heat on the surrounding plastic parts.
Peter
Veröffentlicht : 30/01/2016 11:07 pm
