grub screw fell out. little help
JuanCholo
(@juancholo)
working on a print and a grub screw is sitting on the bed, where did it come from?
i started going through the online manuals but i can't figure out where it came from. the grub is still in the extruder motor from what i can tell.
is there a grub in the extruder bottom? i cannot find any assemblying information on the E3D V6 Full hotend itself
“One does not simply use a picture as signature on Prusa forums”
Postato : 14/05/2017 7:37 pm
cory.w
(@cory-w)
Re: grub screw fell out. little help
Probably pulley hobbey but mine was black. Look at a the other motor Hobbes too. Some have 2 on them.
Postato : 14/05/2017 7:38 pm
JuanCholo
(@juancholo)
not the pulleys just looked them over.
what is the little blue wire sensor thing in the hot end called? does that have a little grub screw holding it from underneath?
ok its a Thermistor
http://shop.prusa3d.com/en/mk2-spare-parts/145-es3.html
does this have a grub sccrew because i think that might be what it is.
update ok i think that was it
i found this: in the Thermistor section it shows a grub screw
https://wiki.e3d-online.com/wiki/E3D-v6_Assembly
Postato : 14/05/2017 8:16 pm
Alsand
(@alsand)
Yes that's the grub screw holding the hotend thermistor, most probably.
When you put it back on, don't tighten it too much or you risk damaging the thermistor body.
Postato : 15/05/2017 1:05 am
