Gigantic bloob of plastic PLA
ozyreusz
(@ozyreusz)
I left my printer printing for 3h and when I came back it was like this
Please help, I don't know what to do and I'm reaching my mental sanity limit 🙁
I burned down the hair dryyer already and lighter is not the best solution
Respondido : 14/04/2017 4:58 pm
JeffJordan
(@jeffjordan)
Miembro Moderator
Re: Gigantic bloob of plastic PLA
💡 you'll find a few of these pictures here at the forum.
advice will always be to use a hot air gun, heat up the stuff GENTLY and start to peel the pla off from the blob. maybe you can carefully use a sharp knife to do so.
never use a lighter, never use an open flame !
if you heat up the pla to much, you can get an opposite effect with hardening it.
pla has is vicat temperature at about 54°C, so above that temperature you should be able to start peeling the stuff off from the extruder. take care not to do more damage as there is already.
Respondido : 14/04/2017 6:15 pm
ozyreusz
(@ozyreusz)
Do you can advise in a solvent solution for this problem PLA. Maybe acetone for a longer period of time. It's in threads sensor and heater holes also on both sensor and heater.
Respondido : 20/04/2017 12:54 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
The only solvent I know of which works with PLA is Chloroform; not readily available...
Peter
Respondido : 20/04/2017 4:43 pm
