Geiger Counter style noises
murloc992
(@murloc992)
Yup, as the title says, I have Geiger Counter style noises going on and unsure where they come from.. I tried to get my ear close to the source, but without getting hit by the printer it proved to be not that possible.. :mrgreen:
It's a MK2S! Just with a MK3 style carriage!
All pulleys were checked, gears on motors were checked. Pretty much checked all the screws I could, nothing was loose.
X and Y axis both use IGUS DryLin aluminum bushings, so they do not rattle for sure. Y bearings are held by custom holders, not the horseshoes.
I have changed X rods recently, so I had to disassemble the X from the Z. Maybe it's Z bearings? They're still default ones I use for a year.
Opublikowany : 09/03/2018 12:15 pm
murloc992
(@murloc992)
Re: Geiger Counter style noises
Switched Z bearings (all 4 of them) to fresh ones. Noise still there. Driving me nutz. 😐
Opublikowany : 09/03/2018 2:35 pm
rob.l6
(@rob-l6)
You need to isolate the noise. For example try testing each axis individually first., without printing anything.
Also, could it be something caught in a fan?
Opublikowany : 12/03/2018 3:10 pm
murloc992
(@murloc992)
Moving every axis is not making the noise appear no matter how violent and fast I get. I have taken the fans off and cleaned them. My blower seems to be tired, but it doesn't explain geiger style noise on movement..
Opublikowany : 13/03/2018 10:27 am
JASII
(@jasii)
Just a thought but have you tried printing the object with no filament loaded? That would see if it might be extruder related.
- MK3s w/Mosquito Hotend- Mini w/Copperhead Hotend- XL - 5 tool -OpenScad -3d Builder -FreeCAD -Alibre -OctoPrint/x3(Pi3B)
Opublikowany : 13/03/2018 12:47 pm
murloc992
(@murloc992)
I found the reason of the noise. It's the hotend fan. It's a MagLev fan, so it seems it's shaky. 😀 Crap.
Opublikowany : 13/03/2018 9:48 pm
rob.l6
(@rob-l6)
Well, there aren't too many things on a printer that can generate high frequency noises. I was thinking fan bearing would be a good possibility as well. Glad I could help 😉
Opublikowany : 14/03/2018 1:42 am
