First Z Calibration Problem
lucien.b
(@lucien-b)
Hey everybody,
2 Days ago i finished building my MK2S KIT. But for some reason i can't get the Z axis to work properly. I've been working on this for the last 2 days and spend over 10 hours re-wiring and checking everything. (also followed the calibration steps in the manual)
When i activate the Z calibration: i move it to the top -> Nozzle is clean cause i never used it yet -> Steppers are up? -> Yes : It starts calibration but all the way in the top, it doesn't go down. When i do this a second time without restarting it does go down, but still way to high above the bed. (dead end)
When i do the selftest: After i checked the fans it said: Please check: endstops wiring Z. (Error - static memory has been overwritten) Is it possible that the P.I.N.D.A. might be broken already? It hasn't been connected wrong in any way, i checked it a couple times. Also didnt zip tie to tight, and took care that the cable would't bent in a bad way.
When i do XYZ Calibration: failed consult the manual. (wich brings me in kind of a dead end)
Mesh bed leveling: Sensor disconnected or cable broken wait for reset.
Anyone might know what my problem is? I got and assembled the printer 04-05-2017 is it possible the P.I.N.D.A. might be broken already? Or that im just missing something?
Thanks in advance!
Lucien Boeijenga
Opublikowany : 06/05/2017 3:19 pm
