First layer issues
Strona 2 / 2
shaun.k2
(@shaun-k2)
Re: First layer issues
Okay so still no luck printing, seems like the moment the printer heats up, all the Live-Z values go out of whack. So I went back to Calibrate XYZ and started again. This time I measured the live-Z values at which the paper stops resisting for each of the 9 points around the bed....
but you still know that the meshbed levelling only works during a print, not when you move the extruder through the menu (either through the axis menu or the live z adjustment level) ?
so what you've "measured" with your values is only of limited usage... and only gives you the information, that your right "bumper" at the top of the z-axis is slightly lower than the left one.... so "calibrate z" delivers a slightly askew x-axis.
I had thought measuring these 9 values gives a good basis for a ballpark estimation of the hyperfine bed correction values. I should add that I flashed the hyperfine firmware, set a live Z of - 0.500mm to get the centre printing fine, and managed to get the rear left corner dialed in, but when it got to the middle left square (the one with - 770), the nozzle was printing into thin air even at +99 bed correction. So I might try to adjust the PINDA slightly to not get such a low value for that point on the bed.
Should I be worried that the bumper on one of the Z axes is higher than the other? Is this an assembly fault and something I should fix before I go any further?
Opublikowany : 05/09/2017 4:00 am
JeffJordan
(@jeffjordan)
Member Moderator
not essentially necessary, because the meshbed levelling should correct the slight skew of the axis, but it would make things easier to dial in the 8 values for the hyperfine bed correction.
ps. I'm going to make a proposal on how to dial in the values at the hyperfine meshbed levelling thread later on...
Opublikowany : 05/09/2017 3:26 pm
shaun.k2
(@shaun-k2)
I'd still be interested in your process, will you post it here or in another thread?
Opublikowany : 07/09/2017 10:05 pm
JeffJordan
(@jeffjordan)
Member Moderator
I will post it at the hyperfine bed levelling thread, as soon as I've tested it here at my printers personally.
I've already prepared a set of tweaked gcodes, with a tiny test patch for every calibration point.
here in advance my idea on how to determine the required correction levels most efficient:
the idea is to dial in the center first with the live z adjustment. then note down the value and proceed with printing single patches for every edge/corner without starting another meshbed levelling (G80), without disabling the steppers and without cooling down the hotend completely (bed remains heated as well).
then dialing in the correct z-height with the live z adjustment again for each corner/edge patch and writing down the determined value for the corresponding spot.
so you'll get 9 "live z adjustment values" in total. subtract the value of the center adjustment level from the remaining 8 and you'll get the 8 correction values to dial in for the 8 meshbed correction points.
and: don't forget the set the live z adjustment level back to the value you've determined for the center spot.
Opublikowany : 08/09/2017 8:29 am
walter.v4
(@walter-v4)
Thanks for the details
Just to make sure I understood the math behind this calibration:
Suppose I have set the "live Z adjustment value" at -350 in the bed center point.
I want now to adjust the "a" corner. My live Z adjustment for that corner is -500.
Am I right I need to enter -150 for "a" ? -500 -(-350)
When finished with the 8 points, I will set back -350 for my live Z adjustment value.
Hope that makes sense!
Thanks
Opublikowany : 08/09/2017 7:26 pm
JeffJordan
(@jeffjordan)
Member Moderator
just provided a detailed description and a special set of gcodes on how to dial in the hyperfine bed levelling.
it took a little bit longer than expected, because my first attempt with the gcodes didn't work as expected. but now it should be easy to understand and to use.
@walter: you can only go for max. +/-99 µm when using the altered firmware with the 8 correction values for the meshbed levelling through menu.
150 would be to much. but from the maths and the principle you are right.
if you need values between +/- 100 and 200, you've to use the G80 command and need to parse the values through the gcode to your printer, as proposed by PJR.
Opublikowany : 11/09/2017 10:11 am
Strona 2 / 2
