Re: Faulty Frame Drills ?
I just checked mine they are the same from the top on each side.
The one that is higher is wrong. Mine are flush at the top on both sides.
Hi Mathias,
I am not near My Printer at the moment, but I don't recall the other top bracket hanging outside the frame!
can anyone else check their frames...
Mathias, can you check the distance from the bottom hole, on each of your Z motor mounts to the bottom of the frame?
it may be that for some reason the whole of your frame is at a slight angle to the hole pattern, which would lead to 'interesting' performance later.
it's probably worth checking out these items and having a word with the helpdesk via chat or email and referring them to this thread...
regards joan
Hi there,
thanks for your answers! I contacted the Prusa support and they will send me a new Frame.
Good result.
Hope all is well with the new frame,
