Faulty Frame Drills ?
Detzi
(@detzi)
Hello,
can someone please verify or neglect that my frame has the mounting holes for the "Z-axis-top-right" and "Z-axis-top-left" wrong? I think they should be on the same higth, shouldn't they?
Thanks in foreward.
Matthias
Napsal : 07/01/2017 3:17 pm
Yukaputz
(@yukaputz)
Re: Faulty Frame Drills ?
I just checked mine they are the same from the top on each side.
Napsal : 13/01/2017 3:05 am
virpobe.p
(@virpobe-p)
The one that is higher is wrong. Mine are flush at the top on both sides.
Napsal : 14/01/2017 3:57 pm
Hi Mathias,
I am not near My Printer at the moment, but I don't recall the other top bracket hanging outside the frame!
can anyone else check their frames...
Mathias, can you check the distance from the bottom hole, on each of your Z motor mounts to the bottom of the frame?
it may be that for some reason the whole of your frame is at a slight angle to the hole pattern, which would lead to 'interesting' performance later.
it's probably worth checking out these items and having a word with the helpdesk via chat or email and referring them to this thread...
regards joan
Napsal : 15/01/2017 2:20 am
Detzi
(@detzi)
Hi there,
thanks for your answers! I contacted the Prusa support and they will send me a new Frame.
Napsal : 16/01/2017 7:44 pm
Good result.
Hope all is well with the new frame,
Napsal : 18/01/2017 12:58 am
