Fails on calibration point #2 (RESOLVED)
Atle
 Atle
(@atle)
Running XYZ calibration, it keeps failing on point #2 – what could be causing this?
Self-tests are all OK.
Original Prusa i3 MK2
Postato : 15/11/2016 7:47 pm
Wirlybird
(@wirlybird)
Re: Fails on calibration point #2
Can you gauge the distance of the PINDA to the board? If it is to far it will not read good.
Also, try a home and see how the PINDA aligns in the circle on the bed. I used this as a guide to adjust teh Z frame.
Postato : 15/11/2016 8:17 pm
Atle
 Atle
(@atle)
Thanks, I had to re-adjust the PINDA 3 or 4 times, seems like I finally got the sweep spot now.
Cheers.
Postato : 15/11/2016 8:40 pm
