failed xyz callibration
Matthew Mcdaris
(@matthew-mcdaris)
I am having problems with the xyz calibration. First point is perfect. Second point it is searching slightly behind the point on the table. Third point it is searching further behind the point position on the table. Its like its looking for points on a bigger table.
Postato : 18/09/2017 7:08 pm
AJS
 AJS
(@ajs)
Re: failed xyz callibration
Hard to tell from your post, but it sounds like you have a stepper that is missing.
Check your belts, make sure they are tight.
Check the grub screw has attached the gear pulley to the stepper motor. If it slips...
Check the wiring on your steppers.
If you do a "settings->move axis-> " X Y and Z, does it move correctly and cleanly?
Maybe post a video of your XYZCal.
Postato : 19/09/2017 4:27 pm
