ED3 LITE
john.s
(@john-s)
ED3 LITE
Hello everyone
i have a prusa i3 hephestos Direct extruder for 1.75 mm filament with 0.4mm nozzle.
and i have a ed3 lite6 24v direct extruder is there a mount for this or can i use the mount that came with the prusa??can i use a 24v on a 12v power supply.
Postato : 01/03/2016 1:37 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: ED3 LITE
Hi John
Firstly, this forum is primarily for the Prusa i3 "original"; very few of us here have much experience with clones.
There are printable parts available on this site here: http://www.prusa3d.com/prusa-i3-printable-parts/ Some of those parts are for mounting the extruder which you may be able to adopt for your own use.
With regard to a 24V heater, if you are running a 12V system, then it would be best to replace the heater cartridge - you will need a standard 12V 30 cartridge like this one: http://e3d-online.com/Electrical/Components/Heater-Cartridge-12v-30w
Peter
Postato : 01/03/2016 9:38 am
