Correct filament idler tension
L33TFR34K
(@l33tfr34k)
What is the best way to set the correct tension for the filament idler?
I have been having occasional jamming issues that I think are related to that.
I found several sources that say to tighten it down pretty hard for harder plastics like pla and abs. But that was also applying to different printers.
So I wanted to see what the mk2s community has to say on the matter.
Napsal : 31/05/2017 10:00 pm
Philip Garibaldi
(@philip-garibaldi)
Re: Correct filament idler tension
Not to tight or to loose, you want it to leave small lines on the side where the hob gear grabs it but not press in so deep that it creates a curling effect on the filament.
Philip G.
Original Prusa i3 MK2S
Turnigy Fabrikator Mini
Napsal : 01/06/2017 12:23 am
Nomad965
(@nomad965)
I would start with the default measurements as per the online manual and back it off a couple of turns till you get the right amount of tension as per phli's recommendation.
Just keep in mind every filament has its own tolerances you really dont want too loose of a setup that it will skip and not to tight that will bend the filament.
Prusa i3 MK2s MK2.5s Mk3 Mk3s BearPrusa Zaribo 320 - Kit Build - Rc Driver - Tweak freak...
“I know nothing about surpassing others. I only know how to outdo myself.” -Bushido-
Napsal : 03/06/2017 1:04 am
