Clean the nozzle
robert.c
(@robert-c)
Clean the nozzle
Hi i'm a very happy cuatomer of your Prusa printer. It works very well!
This morning i was printing a large ABS model and at 70% nozzle stop extruding filament.
I tryed to unload filament and load it again but only few material was extruded.
Do you have any suggestion? Must o clean the nozzle? Don't know how to do it.
Thank u
R*
Respondido : 05/08/2016 2:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Clean the nozzle
Robert
One of the best methods for cleaning the nozzle I have found is the Ultimaker Atomic Method" (Google is you friend...)
Your problem may have been caused by excessive retraction; ensure your slicer settings have retraction set to less than 1mm.
You may also find that you have solid plastic in the heat break/heat sink. To clear this, you will have to remove the extruder fan and heat the nozzle for a few minutes which will allow the blocked plasic to become soft and allow it to be pushed through.
Peter
Respondido : 05/08/2016 2:31 pm
robert.c
(@robert-c)
Hi PJR, thank you for your suggestion.
I'm using Slic3r with last settings downloaded from Support -> Drivers, retraction length is setted to 1.5mm.
Should this be decreased to 1?
I will follow your advice for cleaning the headsink.
Respondido : 05/08/2016 3:08 pm
PJR
 PJR
(@pjr)
Robert
The later driver downloads have Slic3r retraction settings at 0.8mm. It may well be worthwhile that you download and install the latest driver package (1.7.3).
Peter
Respondido : 05/08/2016 4:05 pm
robert.c
(@robert-c)
Peter, are you sure? I see this settings...
Maybe i've made some mistake...
[img][/img]
Respondido : 05/08/2016 4:29 pm
PJR
 PJR
(@pjr)
Latest Windows driver bundle:
Peter
Respondido : 05/08/2016 5:04 pm
David T.
(@david-t)
Your profile is named "Prusa I3" only, MK2 drivers default profiles are named "Prusa I3 MK2 ...". You're using different profile.
Respondido : 05/08/2016 5:39 pm
robert.c
(@robert-c)
Yes, right.
I'm using the profile of Prusa i3 plus printer not for the MK2 because i don't own an MK2 yet.
Btw nozzle is still blocked.. damn 🙄
I removed the fan from the extruder and temperature doesn't grow more than 256 degrees.
If i try to press filament by hand, it doesn't melt.
Don't know, anybody have some other suggestion?
UPDATE: i remove the nozzle from the extruder and i put it in some acetone. I hope abs will dissolve so it will be functional again. 😉
Respondido : 05/08/2016 5:53 pm
robert.c
(@robert-c)
Yeah It works again!!!!
Basically i follow this video !
Thank you all for your help!!
R*
Respondido : 05/08/2016 7:59 pm
