Can't get good print
ryan.f15
(@ryan-f15)
He folks. I'm having problems. I've gone through all the calibrations and everything else. When I did the calibration, I had to dial the z down to -.700 to get a stable print(see picture.) . The very next one was so close to the bed that filament wasn't even coming out of the nozzle. Now I corrected by dialing back to -.500 and the test square looked ok but I can't get a good print. It's almost like leveling is wrong. What should I do?
Postato : 11/11/2017 12:48 am
AJS
 AJS
(@ajs)
Re: Can't get good print
Hopefully you found the steps here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
You should print somethings from the SD Card first, to make sure the printer is working correctly, then shift to thing you slice (as you may have a good printer, but bad slicer settings).
Please post a photo of the calibration square, and an item from the SD card - say the Prusa Logo. If those look good, then I would focus on your model and how you are slicing it. If those look bad, post here and we can try to help.
Postato : 11/11/2017 5:25 pm
ryan.f15
(@ryan-f15)
I did that. I've been back and forth with tech support. Last night I had a good print, and then today I tried to print again and I'm back to having crap prints.
Postato : 11/11/2017 10:57 pm
