Ambient temperature important?
Simon
(@simon-16)
Hello to all,
Ok, I should receive my first printer soon. Meanwhile I'm searching infos to start with all inflrmations needed for my slices!
I would leave the printer in a cold room, should be at 10°C. Does the ambient temperature alter the final result? It's too cold?
Thanks for the help!
Simon
Veröffentlicht : 10/11/2016 10:07 am
mr.m
 mr.m
(@mr-m)
Re: Ambient temperature important?
This is dependent on what material you print with. For many materials it is very important.
Veröffentlicht : 10/11/2016 10:31 am
PJR
 PJR
(@pjr)
Antient Member Moderator
The printer won't work below 15 degrees.
This is a safety feature in case there is an issue with the thermistors and is built into firmware (15 degrees for extruder and 5 degrees for bed).
You will have to warm the extruder with a hairdrier (or similar) otherwise you will get an error mossage on pre-heat.
Colder working temps are fine for PLA, but you will have issues with ABS unless you enclose the printer.
Peter
Veröffentlicht : 10/11/2016 10:51 am
Simon
(@simon-16)
Thank you for the suggestions, I'll try to increase the room temperature or change the place.
Simon
Veröffentlicht : 10/11/2016 12:03 pm
jon.m
(@jon-m)
Peter
What are we talking here? My printer is in my finished basement with heated rooms and carpet, etc... But, there is about a ten degree difference as opposed to the 68 degrees upstairs. Will this ABS? PLA prints fine as is.
Veröffentlicht : 10/11/2016 8:16 pm
PJR
 PJR
(@pjr)
Jon
ABS has to cool slowly otherwise warping/separation will occur. Also ABS does not like drafts.
If you have a look in the Improvements section of this forum you will see many ideas for printer enclosures.
Peter
Veröffentlicht : 10/11/2016 8:48 pm
mr..m.i.k
(@mr-m-i-k)
Peter
68degC is really hot, you sure you did not build on a hot spot? 😉
Veröffentlicht : 11/11/2016 8:41 am
Are we talking centigrade or farenheight?
Joan
Veröffentlicht : 11/11/2016 12:07 pm
Simon
(@simon-16)
I was asking for temperatures in Celsius.
Veröffentlicht : 11/11/2016 3:41 pm
Nigel
(@nigel)
@Joan Its about time we all talk in Celcius or degrees centigrade. For a failure see Joels The 3D Printing Nerds failures in his cold garage late at night. With unboxings and first prints. Its so cold he does not follow the manufacturers unboxing instructions and could have damaged the printer.
Nigel
Veröffentlicht : 15/11/2016 4:21 am
jon.m
(@jon-m)
Peter
Ha ha, 'Merican here - Fahrenheit.
Veröffentlicht : 15/11/2016 6:01 pm
jon.m
(@jon-m)
Since this post I reprinted my entire MK2 kit (basically) over the weekend. I let it run night and day and there was not an issue. Only reason I would consider an enclosure is for the benefit of smell reduction. Honestly though, the ABS was not as bad as some say?! But I am used to working with plastics.
Veröffentlicht : 15/11/2016 6:03 pm
pbnj
 pbnj
(@pbnj)
We run a number of printers in one printer room. I have two Prusa MKII, we found out a couple of weeks ago, when someone did not turn the heat on the one of the printers shut down when the Temp reached 66F. The other one keep working. We normally keep the room between 72 and 78F.
Veröffentlicht : 29/11/2016 3:41 am
Nigel
(@nigel)
My printer room is small and within my house in the central heating environment.
Nigel
Veröffentlicht : 29/11/2016 4:50 am
