Adhension-First Print Issue
John Walsh
(@john-walsh)
Some how the throat connecting the block to the heat dissipater bent slightly.
No idea how, I don't print super hot exotics, just PLA.
I had a spare one and installed it.
Couldn't get prints to stick.
Reran the calibration setup.
https://imgur.com/a/yZiEF
Live Z up? Down? How do I get it to stick?
Napsal : 09/03/2018 10:59 pm
Re: Adhension-First Print Issue
I would turn the speed down to 50% on the LCD, to give you longer to adjust the changes, and I would start by going to a digger negative number (lowering the extruder a little), make small adjustments... if the surface gets worse, you are going the wrong way!
Napsal : 09/03/2018 11:38 pm
