[Cerrado] what's the reason? (attach some images)
kmh
 kmh
(@kmh)
hi, everyone
I have done my first 3d printing ever
but I have found some problem of that
what can I do to solve this?
it's a smooth surface cylinder
Respondido : 28/02/2020 3:41 pm
RE: what's the reason? (attach some images)
Those bumps are caused by the z-seam. You can move it around (Print Settings->Layers and perimeters->Advanced->Seam position) but not completely hide it. It's a limitation of current consumer-grade FFF technologies. That seam has to go somewhere. If the layer has corners, you can tell the slicer to hide it in angles. Unfortunately, cylindrical or rounded shapes don't allow easy hiding. Aligning it to rear might at least put all of the irregularities on one side where you can hide or sand it. Tweaking your filament extrusion rate and linear advance settings can help minimize the size of the seam, but only to a point.
Here's what my seams look like after some tuning and calibration. The selection of filament makes a big difference in appearance. It's not so noticeable in white, but a silver or shiny filament will make the seam more apparent:
Respondido : 28/02/2020 5:38 pm
vintagepc
(@vintagepc)
Miembro
Posted by: @bobstro
Holy crap. And I thought mine were good. Filament calibration time...
Respondido : 28/02/2020 6:47 pm
Speaking of seams, they can be minimized, but it is work, here' what I got mine down to:
Respondido : 29/02/2020 1:16 am
Nikolai
(@nikolai)
Just keep in mind that reducing the seam usually goes hand in hand with worse structural integrity. My functional parts don't look great for a reason 🙂
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 29/02/2020 1:29 am
GKMAKEIT
(@gkmakeit)
Using semi transparent filament can help hide the seams.
Respondido : 29/02/2020 5:35 am
kmh
 kmh
(@kmh)
@gkmakeit
thank you so much
I understand about that
Respondido : 01/03/2020 3:56 am
kmh
 kmh
(@kmh)
@vintagepc
thank you so much
I try to test it
Respondido : 01/03/2020 3:57 am
