[Cerrado] two rolls, one bad?
master moccasin
(@master-moccasin)
two rolls, one bad?
 ​I've been using Prusament filament from when I first got two I3 MK3S printers. I recently got 2 rolls of vanilla white PLA and ran most of it on the CraftBot XL FLOW. I needed to start an 18 hour print so switched to the second roll. It will not stick and or wads up and gets drug around. I tried it on both of the I3 MKS printers and got the same result. I then put the first roll back and tried thinking the file may be corrupt and it worked as expected. I then tried the first roll on both of the I3 MK3S printers and both were perfect. Is it possible I got a bad roll of filament?
George
Este debate ha sido modificado el hace 6 years por master moccasin
Respondido : 13/07/2020 1:46 am
Peter M
(@peter-m)
RE: two rolls, one bad?
Clean bed with dish soap.
Make first layer 100%.
As extra you can try, more heat on bed, more heat on extruder during first layer, first layer slower, clean nozzle before printing.
Water in filament? dry it in a oven.
Respondido : 20/07/2020 7:31 pm
master moccasin
(@master-moccasin)
Thanks Peter,
I'll give it a try.
George
Respondido : 20/07/2020 8:39 pm
