Two colors, single extruder?
jesi
 jesi
(@jesi)
Hi!
Tried to search similar topic, no luck.
I have been using M600 command to make multi color prints.
I'd like to print small item, what has two different colors in same layer.
With M600 that cannot be done.
Can it be done some way? I know, there is lots of filament changes, but...
Thanks!
Opublikowany : 09/09/2017 9:38 pm
AJS
 AJS
(@ajs)
Re: Two colors, single extruder?
You can look at these threads for ideas:
http://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/multi-color-printing-different-way-t4836.html
http://shop.prusa3d.com/forum/hall-of-fame-best-3d-prints-f15/-inlayed-magic-the-gathering®-card-box-and-separa-t5634.html
Please post what you figure out!
Opublikowany : 09/09/2017 10:12 pm
