Support hard to remove
maybe some one can help me tweaking the support settings, some off them are rely hard to remove, it looks like they are copletly "melted" with the real print. What do I have to change that they will be easier to remove?
Thanks for help
Martin
Postato : 03/07/2017 2:14 pm
Re: Support hard to remove
Assuming you are using Slic3r, under the Print Settings tab, go to Support material and change Contact Z distance to 0.2mm. See if that helps.
Postato : 04/07/2017 4:04 pm
