Spiral Vase setting Slic3r
Hi I was trying to print a rocket using the Spiral Vase setting in Slic3r which it worked but some parts of the rocket are clean and the other is messed up,
I was wondering if anyone new what could cause the areas on the print (see picture below) to mess up and the other parts to print correctly.
I am using E3D Edge Filament.
Thanks, Adam
Opublikowany : 11/07/2017 4:49 pm
Re: Spiral Vase setting Slic3r
Is that PLA or other material?
Slow you printing speed and/or give more fan speed. Filament does not have time to cool dawn between layers.
Opublikowany : 14/07/2017 4:02 pm
Topic starter
answered:
Thanks for the info i'll try slowing down the print to see if that fixes it.
its E3D's EDG filament, it uses the same settings as PET.
Opublikowany : 14/07/2017 8:16 pm
