Slic3r Version for MK2S no MMU?
randy.p2
(@randy-p2)
I'm probably just dense but I was having trouble figuring out the Slic3r installation. When I go to the download page I see:
Version 1.9.0 Most recent (September 17, 2017) for MK2/S/MMU
I downloaded that one, thinking it's for all versions. When I go to install it I get these optons:
Slic3r for Original Prusa i3 MK2 / Multi Material single mode
Slic3r for Original Prusa i3 MK2 Multi Material
Should I choose the single mode option or do I have to look for an older version of the program without MMU in it?
Thanks!
Veröffentlicht : 17/11/2017 4:14 pm
ron-f
(@ron-f)
Re: Slic3r Version for MK2S no MMU?
You can install both. Prusa3D Slic3r MK2 Multi Material is just a shortcut to the same program but with a different folder settings.
- Prusa3D Slic3r MK2 shortcut is "C:\Program Files\Prusa3D\Slic3rPE\slic3r.exe" --DataDir "C:\Users\Public\Documents\Prusa3D\Slic3r settings MK2 190"
- Prusa3D Slic3r MK2 Multi Material shortcut is "C:\Program Files\Prusa3D\Slic3rPE\slic3r.exe" --DataDir "C:\Users\Public\Documents\Prusa3D\Slic3r settings MK2MM 190"
If you have no MMU run Prusa3D Slic3r MK2.
And you can even change the settings of that program to set your printer as a MMU (select 2 or 4 extruders ans check single extruder multi material).
Veröffentlicht : 17/11/2017 4:47 pm
randy.p2
(@randy-p2)
OK. Thank you for the reply!
Veröffentlicht : 17/11/2017 5:19 pm
