Slic3r PE closes a hole but others don't
awilde
(@awilde)
Hi
I have a STL for a MK3 Fan shroud but Slic3r PE closes the big hole. Is there a option that I have to select or deselect?
With Simplify3D everything is fine
Postato : 19/01/2018 5:01 pm
Holger
(@holger-2)
Re: Slic3r PE closes a hole but others don't
Hello, I'm new to Prusa and see the same issue between Slic3r and Slic3r-PE using the same .stl file, is there any work around to fix this problem?
There are some holes missing in the preview!
Thanks! 🙂
Postato : 15/08/2018 6:30 am
Is it also filling the interior with sparse infill?
Can you link the STL? I've tried nozzle ducts before with Slic3r without issue.
Postato : 15/08/2018 6:48 am
Holger
(@holger-2)
Thx for your fast reply and your help, the .stl file is Scheibe1.stl.
Yes, it also fill the interior with sparse infill.
Here is a screen using PrusaControl, it shows the holes like other apps too:
Postato : 15/08/2018 7:31 am
Knickohr
(@knickohr)
Utenti Moderator
[mod_mode on]
Please do not double post, 🙁
Solution :
https://shop.prusa3d.com/forum/allgemeine-diskussion-ankuendigungen-und-veroeffen-f313/slic3r-pe-bohrungen-fehlen-in-der-vorschau-t23823.html#p102868
[mod_mode off]
Thomas
Postato : 15/08/2018 9:48 am
