Slic3r Always Crashes on Slice
ben.d5
(@ben-d5)
I've been trying to export a simple model (a name plate) that I created in Blender, import it in Slic3r, and then slice it using "slice now", but every time I hit the button it crashes the program.
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
I've tried starting with both OBJ and STL files and with using different export settings and I still get the same error. When I load the pre-loaded files they all seem to work.
How do I find more information to help troubleshoot what is going wrong? I'm currently on Windows 8.1 and using Slic3r Prusa Edition 1.36.2.
Postato : 19/08/2017 7:10 pm
ben.d5
(@ben-d5)
Re: Slic3r Always Crashes on Slice
Well it looks like it had to do with the unit setting in Blender. I had it set to "Metric" to model everything to scale, but switching to "None" (Blender Units) seems to have stopped the crashing on slice problem.
Postato : 19/08/2017 7:36 pm
