Slic3r - allign face to the build plate
janis.j
(@janis-j)
I have searched the web and Google, but cannot find the answer. So, i suppose, it is not implemented? Do I have to export model from my modeling tool already on 0 Z with right face down?
Opublikowany : 10/03/2017 3:31 pm
gabriele.s2
(@gabriele-s2)
Re: Slic3r - allign face to the build plate
The object doesn't have to be at 0 Z, Slic3r will move it up or down as necessary.
You can also rotate your object however you want from the menu.
If you need more sophistication, it's a better idea to use a mesh editor or your modeling tool.
- Gab
Opublikowany : 10/03/2017 7:05 pm
richard.l
(@richard-l)
Member Moderator
What I think he is looking for is the Place Surface on Bed that Simplify 3D has. It is quite handy but it doesn't exist in Slic3r.
Opublikowany : 12/03/2017 4:19 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
There is a Slic3r issue to implement this, but the day has only 24 hours.
https://github.com/prusa3d/Slic3r/issues/147
Also the upcoming Prusa Control will have it.
Opublikowany : 14/03/2017 12:00 pm
Lukáš Matěna
(@lukas-matena)
Implemented in Slic3rPE 1.41.
Lukas Matena
PrusaSlicer development
Opublikowany : 10/09/2018 8:13 am
