Slic3er can't open file
Hey!
I'm having trouble opening this obj. file in scli3r, but it works perfectly in Cura.
https://www.dropbox.com/s/nq7iudk15y3nfsm/Fan%20grid.obj?dl=0
It's giving me the error "Can't call method "objects_count" on an undefined value at C:/PROGRA∼1/Prusa3D/Slic3rPE/lib/Slic3r/Model.pm line 18"
Thanks in advance
Opublikowany : 11/07/2017 11:35 am
Re: Slic3er can't open file
I have only opened .stl in Slic3r. Maybe convert it to .stl using Meshmixer first?
Opublikowany : 13/07/2017 2:29 am
