Simplify3D settings
Strona 1 / 5
Josef Průša
(@josef-prusa)
Member Admin
Simplify3D settings
If you want to try out Simplify3D i made settings for it.
Just PLA now, let me know how well does it work for you 😉
For installation just use File –> Import FFF settings
UPDATE 18.12.2015
Separated the settings into multiple files to have more control 🙂
UPDATE 24.1.2016
Added the 3mm ABS production setting we use to print our parts.
Founder and owner / Majitel a zakladatel
Opublikowany : 03/12/2015 7:17 pm
Tonias
(@tonias)
Re: Simplify3D settings
Thank you for this! Will try out those settings today.
I've always had some issues with blobs at the beginning and end of lines with Simplify3D, so I hope this will help with that.
Do you have any directions regarding "Retraction" and "Nozzle Wipe" settings for ABS?
Opublikowany : 08/12/2015 7:49 am
K6TJO
(@k6tjo)
Great thank you!. I was just about to ask for this.
Opublikowany : 16/12/2015 8:01 pm
K6TJO
(@k6tjo)
Can you setup your recommended ABS fff file?
Opublikowany : 16/12/2015 8:03 pm
Marco Mena
(@marco-mena)
These worked great! Printed the T-Rex skull at 25% scale with these and it came out great - much better than the default settings. Thank you!
Opublikowany : 17/12/2015 7:08 am
Josef Průša
(@josef-prusa)
Member Admin
I updated the settings in the first post 🙂
Opublikowany : 18/12/2015 8:15 pm
K6TJO
(@k6tjo)
Thank you. Don't forget us old-timers with the 3mm i3 version. Thanks
Opublikowany : 18/12/2015 8:22 pm
roger.s
(@roger-s)
Hi I am thinking about order simply3d software. I am using slic3r at the moment. In general I think slic3r has some high poly object issues.
Has anyone some experience here with simplify3d?
Best
rog!
Opublikowany : 20/12/2015 2:36 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Roger
Have a look at KISSlicer
Peter
Opublikowany : 20/12/2015 3:28 pm
hans.c
(@hans-c)
The PLA settings are working very well for me so far. I hope you'll soon be adding Simplify3D settings for PETG, NinjaFlex, etc. etc.
In the meantime, Merry Christmas! 😀
Opublikowany : 21/12/2015 8:05 pm
jmmprog
(@jmmprog-2)
Hi do tou have a setting for ABS 1.75.
thank you and merry christmas 🙂
Opublikowany : 25/12/2015 2:07 am
Cipis
(@cipis)
My settings for ABS 0.2mm. Works fine so far.
Opublikowany : 25/12/2015 8:33 pm
fl0PPsy
(@fl0ppsy)
The PLA settings work quite well thanks for posting those.
Would love to see some settings for ABS and Ninjaflex.
Edit: Thanks for the ABS settings roman.t will give them a try.
Opublikowany : 26/12/2015 9:36 am
Cipis
(@cipis)
updated profile (nozzle wipe removed) + new one
Opublikowany : 31/12/2015 5:50 pm
luc.e
(@luc-e)
Just bought the program and looks very easy to use with plenty of options and great previews.
PLA setting seem to work well but I noticed the cooler for the object stays on after completing the print.
Something special needed for .05 mm or can we just decrease the layer height and create a PLA EXTRA DETAIL profile?
Opublikowany : 01/01/2016 9:59 pm
Cipis
(@cipis)
look at first post, there is updated version of settings "simplify3D_18_12_2015.zip" (there is updated script to turn of print fan after print is finished). Or you can add "M107 ; turn off fan" line to Ending script tab.
Opublikowany : 02/01/2016 11:19 am
fl0PPsy
(@fl0ppsy)
Just wanted to say thank to roman.t for posting the latest 2 ABS settings files. They work quite well so far.
Opublikowany : 03/01/2016 10:31 am
Cipis
(@cipis)
I am glad if it helped somebody. I am testing bridges setting now, so far 80% extrusion multiplier and 100% speed works OK for things I printed recently (3D printer parts). These settings are not included in those setting files (you can set it on "Other" tab).
Opublikowany : 03/01/2016 11:50 am
fl0PPsy
(@fl0ppsy)
Thanks for the Bridge setting. It has helped make the Bridges a bit cleaner.
One tweak I have made was to set the "Outline Overlap" to 22%. The solid layers are much nicer now.
Opublikowany : 05/01/2016 2:57 am
dennis.f
(@dennis-f)
Is the Outline Overlap and bridge settings for ABS only?
Thanks,
Dennis
Opublikowany : 12/01/2016 3:47 am
Strona 1 / 5
