shifting layers on X axis
eduard valentino.b
(@eduard-valentino-b)
I'm printing a small enclousure for a bar code reader but I'm getting what seems to be shifting layers on the X axis.
I've already made sure to have the belt tense and after tensing the problem has decreased but it's still there.
No problem on the y axis. ( Actually there was the same problem but I solved it tensioning the belt).
Any suggestions?
I'm printing with ABST at 255 ºC / 100 ºC.
Publié : 20/11/2016 6:13 pm
stevehlau
(@stevehlau)
Re: shifting layers on X axis
Try checking your X-belt tension. It might be loose and cause the X motor skip steps.
Publié : 21/11/2016 11:18 pm
eduard valentino.b
Actually this is the result having the X-belt tensioned. Before the shifting was much worse.
Publié : 22/11/2016 12:41 am
stevehlau
(@stevehlau)
How about the set screw on your belt gear on the x motor? It happens when it came loose. Check that as well.
Publié : 23/11/2016 1:52 am
