rigid.ink PLA Plus+ settings
Chris
(@chris-48)
Hello - I'm, trying to dial in settings for a spool of rigind.ink PLA Plus. I am using a temperature tower from 3DMakernoob.
http://www.thingiverse.com/thing:2092820
I've set the sections to vary in temp. from 215 to 235 C starting from the bottom in 5 degree increments. My settings from S3D are;
Default Printing Speed - 40 mm/sec
Extrusion Multiplier - 1.00
Cooling 75%
It looks like too much cooling on the cylindrical section?
Any suggestions will be greatly appreciated.
Best,
CTR
Publié : 16/03/2017 12:26 am
Knickohr
(@knickohr)
Membre Moderator
Re: rigid.ink PLA Plus+ settings
Hmmmm,
looks like this material likes cold temperatures. Have you tried less than 215° ? I found that some PLA print best with lower temperatures.
Thomas
Publié : 16/03/2017 8:53 am
StephanK
(@stephank)
Strange, Thomas Sanladerer tested RigidInk PLA Plus with 235 / 60 at 100% Fans on his MK2
https://www.filaween.com/#/browse/rigidink-plaplus-pla
but your temp tower clearly shows colder seems better. I second KnickOhrs suggestion, try another temp test from 200 on up..
Publié : 16/03/2017 2:55 pm
Chris
(@chris-48)
Thanks for the feedback - I'll try a cooler tower tonight.
Best,
Chris
Publié : 16/03/2017 2:57 pm
