Removing flex from PEI sheet?
borgqueenx
(@borgqueenx)
Any tips for removing semi-flex from the PEI sheet?
Its really difficult as a spatula wont get under it.
Postato : 11/01/2017 5:43 pm
mavu
 mavu
(@mavu)
Re: Removing flex from PEI sheet?
use gluestick before you print 🙂
other than that, the only thing that helps,m is that the print is flexible and you can bend it up. Try a razor on one edge to get purchase, and then spatula?
Postato : 12/01/2017 8:41 pm
Not much help now, but I use talcum powder rubbed into the PEI before I print with TPU / TPE...
and PETG...
Joan
Postato : 12/01/2017 10:45 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
Did you try the cooling spray trick ?
Postato : 13/01/2017 12:19 am
jgillick
(@jgillick)
What is the cooling spray trick? I can't find anything about it.
Postato : 02/03/2019 10:19 pm
One last ditch possibility: If you can heat the bed up to temps where the material softens, you might be able to get it to peel up. There's a risk of the printed part deforming however.
Postato : 02/03/2019 10:40 pm
Put the sheet in the freezer for 30 minutes or more (longer for larger parts), see if that helps the parts release during a flex.
Postato : 03/03/2019 9:47 am
Utenti
Freezer or cooling spry works for me. Print reeases automatically.
Postato : 03/03/2019 2:14 pm
