Projecting an image on to a 3D print w/ multi-material?
Just saw how to project an image onto a 3D print:
Anyone with the multi-material play around with this method willing to share some photos?
Napsal : 29/04/2017 11:52 pm
Re: Projecting an image on to a 3D print w/ multi-material?
Hi David,
I think you misunterstood what this special trick does. It only adjusts the speed of the print in the parts that have a slightly different color. So you can use it with a single extruder.
The extrusion where the speed is slower or higher has a slightly diffrent shine to it and so it is possible to see it.
Hope that helps,
Bastian
Napsal : 30/04/2017 1:50 am
