Printing problem with 0.25 nozzle
lopster
(@lopster)
Hi everyone. I've been playing around with the mk2 for a bit now and recently switched from the standard 0.4 to the 0.25 nozzle. However when testing out models that printed almost perfectly with the bigger nozzle i get a lot of stringing, holes, etc. with the smaller nozzle.
I used Slic3r with the '0.2mm NORMAL' and the '0.05mm DETAIL 0.25 nozzle' settings provided by Prusa for the two prints you can see below (sorry for the bad quality; red doesn't work very well for photos it seems).
I'm an absolute beginner when it comes to 3D printing so if anyone could help me with this it would be much appreciated 🙂
Opublikowany : 14/01/2017 8:48 pm
Matt3o
(@matt3o)
Re: Printing problem with 0.25 nozzle
probably you have to play a little with the extrusion multiplier. try to increment the filament flow a little. Also maybe you need more perimeters.
Opublikowany : 15/01/2017 11:15 am
