Printer parts Slic3r error
luc.e
(@luc-e)
Not sure if anyone have the same issue but when I try to Add the "Extruder-motor-side.stl" 1.75 to Slic3r it "Auto repaired 23 errors". Wanted to print a new one as the original one deformed after I had a thermistor failure. Very happy with the Prusa support as they send me a new one immediatly 😀 .
When I try to export to G-code Slic3r just hangs. Any tip is welcome.
Opublikowany : 03/12/2015 11:56 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Printer parts Slic3r error
Hi Luc
Can you please let me have a link to that file; I will try it.
It may be that you need to repair the file, either with NetFabb or online: https://netfabb.azurewebsites.net/
You could always try a different slicer (I prefer KISSlicer, but also use Cura).
For me, KISSlicer produces more accurate results with fewer issues, whereas Cura is the quick and easy solution. Cura version 15.04.02; I found later versions very poor in comparison.
Peter
Opublikowany : 03/12/2015 12:10 pm
luc.e
(@luc-e)
Hi Peter,
Thanks for the reply. Here is the link, standard file downloaded from the Prusa website.
http://1drv.ms/1QgOUBe
Luc
Opublikowany : 03/12/2015 12:29 pm
luc.e
(@luc-e)
Peter,
Do you have the G-code file you use internally?
Luc
Opublikowany : 03/12/2015 12:35 pm
PJR
 PJR
(@pjr)
Hi Luc
Yes there are a couple of errors found with KISSlicer, but nothing significant. Slices and saves OK.
If you want me to slice it for you then please tell me temp/layer height/support etc. and I can slice and put the gcode onto my FTP for you.
Peter
Opublikowany : 03/12/2015 12:42 pm
luc.e
(@luc-e)
Hi Peter, Yes please. Thanks!
Opublikowany : 03/12/2015 12:51 pm
PJR
 PJR
(@pjr)
Luc
I think I can see a problem; there are a couple of small extrusions required which are floating in mid-air:
The good news is that the STL will upload to Tinkercad for fixing.
Peter
Opublikowany : 03/12/2015 12:54 pm
PJR
 PJR
(@pjr)
Luc
There are a couple of gcode files on my FTP, one for PLA the other for ABS
PLA: 205, bed 45
ABS: 255, bed 100
Both sliced at 0.2mm layer, 16.7% infill, 3 loops and 0.4mm nozzle. No support or raft.
FTP Details: ftp.rumble.si
Username: PrusaUser
Password: resUasurP
Peter
Opublikowany : 03/12/2015 1:03 pm
luc.e
(@luc-e)
Great support, thanks Peter. Will give them a try.
Luc
Opublikowany : 03/12/2015 1:35 pm
luc.e
(@luc-e)
Peter,
FTP does not allow connection from my IP address.
Luc
Opublikowany : 03/12/2015 1:39 pm
PJR
 PJR
(@pjr)
Hi Luc
You were getting a connection. Try this link: ftp://PrusaUser:[email protected]
You may need to copy/paste into your browser.
And BTW, I have nothing to do with Prusa Research; just and interested printer...
Peter
Opublikowany : 03/12/2015 1:48 pm
luc.e
(@luc-e)
OK Peter. Unfortunately I tried with FTP client, IE, Chrome... Not allowed in. Do you have OneDrive?
Luc
Opublikowany : 03/12/2015 2:02 pm
PJR
 PJR
(@pjr)
Hi Luc
Sorry, I am a tad old-fashioned... No OneDrive.
I have tried the link with both IE and FireFox from a remote site in the UK and it works fine. Maybe something at your end (windows firewall?) blocking.
Try downloading KISSlicer and slice with that.
Peter
Opublikowany : 03/12/2015 2:34 pm
PJR
 PJR
(@pjr)
Luc
Apparently, I can add the files as an attachment as a ZIP file.
So here they are (hopefully)...
Peter
Opublikowany : 03/12/2015 2:37 pm
luc.e
(@luc-e)
😀 Got them. Thanks!
Opublikowany : 03/12/2015 2:47 pm
amanda.r
(@amanda-r)
Hi guys,
I'm getting a similar error with the extruder carriage side (only it's like 60000 errors in Slic3r). Do you think you could make a gcode for that side when you get a chance? Or point me to correct code? I am printing out the entire extruder for spare parts. Thanks!
Opublikowany : 26/12/2015 2:37 am
PJR
 PJR
(@pjr)
Hi Amanda
It's a tad difficult to slice something for someone else; I will if you let me know what settings you need.
Have you tried running the STL through NetFabb? I believe that the program is supplied in the driver package.
Peter
Opublikowany : 26/12/2015 11:40 am
Cipis
(@cipis)
Hi, download STL below and you will be fine even with slic3r. Interesting thing is, that slic3r for MAC dont have problems with original extruder STLs from PR site, only Windows Slic3r do :). Josef knows about it quite long time, I dont know if he decided to replace these problematic STL files or not.
Opublikowany : 26/12/2015 11:51 am
amanda.r
(@amanda-r)
Hey thanks for the files! I'm printing out the spare parts now. Much appreciated!
Opublikowany : 26/12/2015 4:46 pm
