Print settings Easy Wood (Form Futura)
amprint
(@amprint)
Hi guys,
has somebody experience with Form Futura's Easy Wood filament? I am trying to print the coconut filament but I'm experiencing a lot of stringing.
I am currently using the following settings:
Hotend: 200°C
Bed: 0°C
Retraction: 2.5mm
Retraction Speed: 40mm/s
Travel speed: 150mm/s
I know that should play with retraction when experiencing stringing, but I already clogged my noozle a while ago while increasing the retraction (unfortunately don't remember the settings I had) and don't want to have this again.
I'll try to increase it and hope it helps, but maybe somebody has another idea i could try....
Design, Print, Repeat
Veröffentlicht : 21/05/2017 10:48 pm
amprint
(@amprint)
Re: Print settings Easy Wood (Form Futura)
Okay, got it dialed in quite good. Not perfect but way better...
Used 0.2 NORMAL PR Slic3r settings with the following adjustments:
Travel speed: 200
Extrusion multi: 1
Extruder temp: 180/170
Bed temp: 30
Retraction: 0.8
Z Lift: 0
Lowering the temp to 180/170 was the most important change. Hope it doesn't lead to any problems since Form Futura recommends 215 +-5°C...
Veröffentlicht : 10/06/2017 12:19 am
