[Zamknięte] PE Slic3r failed to slice Digital Sundail
david.b14
(@david-b14)
I was trying to print the digital sundial with PE Slic3r, it failed at z=6.00 for the Gnomon_Southern.stl file.
The model is missing a part in the corner. Cura seems to slice it okay.
http://www.thingiverse.com/make:288077
Update: the Gnomon_Southern_NETFABBED.stl worked okay on PE Slic3r as far as I can tell...printing now.
Opublikowany : 14/01/2017 6:49 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Re: PE Slic3r failed to slice Digital Sundail
David,
thanks for the heads up. It would be much more convenient for me, if you could please add the issue into the issue tracker.
https://github.com/prusa3d/Slic3r/issues
Thanks
Opublikowany : 19/01/2017 12:08 pm
david.b14
(@david-b14)
No problem, I will do this in moving forward. Thanks for the excellent work on the PE edition of Slic3r, it is may favorite of the ones that I use.
Opublikowany : 19/01/2017 2:07 pm
thatdecade
(@thatdecade)
RE: PE Slic3r failed to slice Digital Sundail
Ran into this issue too and found this thread at the top of the google results.  Here is the solution:  The model is broken.
Mojoptix uploaded an updated model labeled NETFABBED that slices correctly in PrusaSlicer.
This post was modified 6 years temu by thatdecade
Opublikowany : 29/02/2020 2:33 am
1 ludzie polubili
rmm200
(@rmm200)
One of the few times I approve of a necroed post (over 3 years ago...).
Good find.
Opublikowany : 29/02/2020 4:28 am
