Orienting objects on the bed
Frank O
(@frank-o-2)
So I'm waiting for my MK3 kit, which will be the first 3D printer I've yet owned. I've been learning Fusion 360 to use as my primary CAD program. A friend who has a MK2 suggested using Astroprint, which I have not yet learned much about.
While learning Fusion 360, I started with a video by a presenter who asked us to change the axis orientation so that the Z axis is up. So I went ahead and did that, and created some simple designs with that orientation.
However, I then decided that I preferred the videos by another presenter, who has his Fusion 360 set to Y up, so I changed mine back to that. Now I have some designs in that orientation. However, I notice that when I open my older designs, they still display with the Z axis up.
Here's my question. When I get to the stage where I'm actually preparing one of these designs to send to the MK3, am I going to need to worry about whether the orientation will create any problems with the object being well-located on the printer bed? If so, where is this usually tweaked? In the CAD program, in Astroprint, or in a setting on the printer? Is there anything good to read about this particular topic?
Veröffentlicht : 14/12/2017 5:18 am
rufflez
(@rufflez)
Re: Orienting objects on the bed
No, you can rotate the design in the slicer around any axis.
Veröffentlicht : 14/12/2017 5:31 am
