moving SLICR settings
PedalDoc
(@pedaldoc)
I work between my laptop and desktop a fair bit.
been working on the desktop today and finally got some settings I really like on the desktop and need to export them to the laptop.
is there an easy way to copy a set of files or a folder or two over to make this happen?
Thanks
Shawn
Napsal : 02/01/2017 3:51 am
PedalDoc
(@pedaldoc)
Re: moving SLICR settings
FOUND IT.
if you want to move a single print profile you go under file EXPORT if you want to move ALL your profiles printer and filament then you can choose batch export. then it exports ALL the filament and printers at once as an ini file that you can import into the other system
Napsal : 03/01/2017 1:31 am
